3" vs 2.5" crossover pipes....LETS LAY IT TO REST!!
Old Oct 20, 2011 | 09:22 AM
  #41
BlackWS666's Avatar
Originally Posted by Fireball
its roughly the same size as a 3.5" pipe. thats what I used to feed my T6 flange and it was relatively close. Two 2.5" pipes is nearly identical (just a touch bigger) in area as a single 3.5.
I really never thought about doing that number crunch of the T6 opening being relative to the exhaust pipe size. Good call though, that makes a lot of sense!!!
Old Feb 23, 2012 | 11:17 PM
  #42
BlackWS666's Avatar
Digging this thread back up because i bought all the stuff to make a new crossover pipe. Going with 2.25" pipe. We will see what the difference is at the 7psi zone on my car. All other things should be identical. Even the tune. I will make a pull of the dyno once the e70 crap switchs back to e85 and post results. Also may go to the track before a retune or dyno time and make a few low psi runs to see the difference.
Old Feb 24, 2012 | 01:21 AM
  #43
kmracer's Avatar
im curious to see how things turn out.
Old Feb 24, 2012 | 06:23 AM
  #44
dschmittie1's Avatar
Your not going to get a really good comparison since you changed converters as well
Old Feb 24, 2012 | 06:32 AM
  #45
Sarg's Avatar
Should be interesting. I am going 2.5" with my T6 build.
Old Feb 24, 2012 | 07:41 AM
  #46
BlackWS666's Avatar
True. Well then the results may be a little off. I guess i should run the old converter if i wanted a 100% legit test huh.
