how much is acceptable pressure drop?
Old Mar 9, 2004 | 11:37 PM
1dirtyZ's Avatar
Default how much is acceptable pressure drop?
how much pressure drop is concidered normal on an intercooler?
i'm asking cause i see 15 psi before the intercooler and 11 after it.
should i be looking for another intercooler?
Old Mar 10, 2004 | 12:14 AM
M_Minnick's Avatar
You have to understand that part of the pressure drop is actually a result of the intercooler doing its job. As the air temperature is reduced, so is it's total volume, which will result in a lower boost reading. By taking a pre-intercooler and post-intercooler air temperature reading, along with the boost results, you will get a better idea of how efficient your intercooler is.
Mike
Old Mar 10, 2004 | 05:44 AM
cablebandit's Avatar
Good point...I dint realize the temp drop affected the psi shown like that.
Old Mar 10, 2004 | 05:50 AM
smokinHawk's Avatar
which intercooler do you have?
ill have to see what my IC is before i switch it.
Old Mar 10, 2004 | 08:22 AM
1dirtyZ's Avatar
i'll have to check the temps, good point!
it's a custom unit.
