ARP Head Studs/LS9 Gasket?
Old Oct 23, 2011 | 08:17 PM
Wicked69's Avatar
Default ARP Head Studs/LS9 Gasket?
I have a 5.3 out of a 2003 Suburban and am using the stock heads and possibly changing down the road to a set of 317's. This will be on a twin pt62's. What part #'s for a Head stud kit from ARP and for the good LS9 head gaskets that everyone is using? Also, I can get a deal from Probe if there is anything from them that could be utilized.
Thanks in advance.
Old Oct 23, 2011 | 10:48 PM
BLOWNBLUEZ06's Avatar
You'll have to talk with the guys in the ARP shop if you want the good studs. You need to get studs comparable to 234-4319's, but for a pre-04 block. I have bought them before, but had to go through 3 or 4 different people before they told me it was even possible to get them. When I got to the last guy, he was like "oh yeah.....I can fix you up!" and he sent them off that day. Everyone else was saying they would be custom one-off pieces for the 4 corner studs.
The pro series (aka 2000's") are way better than the 8740's and you need all the help you can get with boost and a stock head. I was running 1021RWHP with AFR heads, those studs and LS9 gaskets and when I pulled the motor apart, it was the first time I saw absolutely no breach of combustion across the sealing rings.
Old Oct 24, 2011 | 01:32 AM
KILLER-LS1's Avatar
Youre talking about getting custom "2000" series head studs which most people dont do. It pretty obvious this guy isnt doing a MAX EFFORT build.
OP, If you want the regular head studs that everybody uses you need one of the numbers below.
Here is the info straight out of the catalog:
LS Gen III 2003 & Earlier (Different height on corner studs): 234-4316
LS Gen III 2004 & Later (All same length Studs): 234-4317
Old Oct 24, 2011 | 08:27 AM
Wicked69's Avatar
Thanks. Yeah. Not an all out build. I appreciate it.
