good heads for procharger?
Old Oct 25, 2011 | 10:54 AM
usnfenix's Avatar
Default good heads for procharger?
car is an 01 ss, LS1, A4
looking at texas speeds PRC heads for my procharger setup, and i am looking at three head choices, and only these three i can afford with the leftover procharger money. so no "id save and buy these" comments please. also a buddy of mine who owns a s/c foxbody told me i should lower my compression that it will help the engine perform better with the procharger. if this is true then which of these three heads and what combustion chamber should i mill them to? will be a d1sc procharger on 8 rib pulley
PRC stage 1 6.0L ported heads
NEW GM 317 Cores
2.00"/1.55" GM Valves
65-72cc chambers
PRC stage 1 LS6 ported heads
NEW GM 243 or 799 Cores
2.00"/1.55" Standard GM Valves
PRC stage 2 5.3L ported heads
NEW GM 862 or 706 Cores
2.02"/1.575" Stainless Steel Valves
58-63cc Chambers
also sry if this is dumb but the 5.3, 6.0, ls6 is confusing me, these will all fit on an ls1 block right?
Old Oct 25, 2011 | 11:00 AM
djfury05's Avatar
Yes any of those heads will work on your ls1.. get the first ones the 317s and leave them at 72cc
