PCV drawing and question
Old Oct 26, 2011 | 07:11 PM
69x22's Avatar
Default PCV drawing and question
For this system to work properly I have to have a breather in the valve cover right?
Would you guys use the system in the drawing or would you mount 2 baffled catch cans with a -10 line from each valve cover?
Right now it comes from the lifter valley to a catch can then to the inlet hat of the Pro Charger, at idle it puffs a little out of the valve cover breather, and I think some oil is getting into the Pro Charger under RPM.
Old Oct 26, 2011 | 07:52 PM
oange ss's Avatar
2 catch cans are goin to pull against each other makin the system null
valley cover--->catch can--->vacuum source(air filter location) then a fresh air source forthe engine
