Dual 38mm wastegate placement
Old Oct 27, 2011 | 02:05 PM
dville_gt's Avatar
Default Dual 38mm wastegate placement
Per advice I was given I bought 2 38mm wastegates for my setup.
I am trying to figure out the best way I can go about mounting them.
The plan at this point is to use 1 passenger side c6 manifold on the passenger side like this (this is in order to clear the a/c compressor which mounts down low on the passenger side):
Then use one forward facing passenger side truck mainfold on the driver side like this:
So with that said the rest of the piping I plan to do like this (excuse the terrible photoshop job, just found this picture of a s400 mounted in a fox and modified it to how I plan to mine):
Will this work with the passenger wastegate being a decent distance away from the merge? Would it be better to just try to cram them both above the 5" d/p? Also, if I plan to run the w/g's into atmosphere do I need to add any pipe to direct the exhaust gasses or can I just vent them out toward the ground, etc.?
Thanks.
Old Oct 30, 2011 | 11:41 AM
black98ws6ta's Avatar
I like your first two pics!
On page 4 of this pdf you can see a diagram that shows you what really matters about waste gate placement. I would move the gates to the outside of the bend so that if you draw a straight line through the pipe coming off of the exhaust manifold it would hit the face of the valve on the gate directly.
http://www.precisionturbo.net/tech/i...structions.pdf
