Boost Leaks at Intake Manifold Gaskets
Here is the run down of my problem...
2004 C5 Z06 w/ A&A kit with a 3.8 pulley
SD Tune with HPtuners (2 bar sensor mounted in the stock location)
Methanol Injection
Cylinders/Pistons are OKAY.
We are seeing 10psi at redline at the SD sensor and boost gauge. The car is down on horsepower (100+ down) and will except 20 degrees of timing w/ methanol injection. A&A says we should be at 13 degrees w/out methanol injection.
I pulled the manifold during the kit install, to install the 2 bar SD sensor. During this I DID NOT put in new gaskets. However, since my last tuning session (when we believed this might be the problem), I installed new gaskets. The originals were very flat.
