Head bolts or Head Studs?
With that said, do I need head studs or head bolts and do they need to be ARP? I am trying to do this on a budget. Thanks in advance. This site has helped a ton in my build so far.
5.3 out of a 2003 suburban Stock bottom end
Arp rod bolts
LS9 gaskets
Patriot Gold Dual valve springs
XER273 224/230 .581/.588 114
Twin Pt62/62's .58 AR on E85
LS2 HD timing Chain
The plan is to not exceed 19lbs of boost. That is the plan anyways. I am hoping to achieve my goal of sub 6 sec over the 1/8th mile. I also want this to last a while and therefore not get greedy. Wasn't sure if I could get away with bolts and a different brand if quite a bit cheaper.
With that said, I ran 14psi for years on ARP BOLTS and MLS gaskets with no issues.
