Has anyone ran a FAST intake with boost yet?
Old Apr 14, 2004 | 07:14 PM
PurEvl's Avatar
I run it right out of the box the way it came. Slowhawk had tested it on a few H/c cars also and did a little light porting on it. But nothing indepth
Old Apr 14, 2004 | 07:41 PM
Slowhawk's Avatar
LS1Tech Sponsor
Runners are in,minor porting to remove flash and stuff.There is no reason to remove the runners on a daily driver,maybe a little benifit on a strip only car.
Old Apr 14, 2004 | 09:13 PM
Wicked_Hugger99's Avatar
you guys are making me think i wasted some cash. Im getting the LSX put on mine with ys-trim, 348ci etc etc done by Speed inc. guess ill let you know how it does
Old Apr 15, 2004 | 03:01 AM
SS00Blue's Avatar
Originally Posted by MIGHTYMOUSE
MY hate thing? oh please do come on
Yeah, you know, hatin' on RR and anyone that defends his kit... That hate thing. <<< back at ya.
I don't hate anyone. Just call them as they are. I'm sure I could walk right up to you and we'd get along fine... until I told you who I was... Already done it to Geoff.
Oh yeah... FAST. If I had the cabbage, I'd get one, but the difference from the LS6 just doesn't inspire me to spend the additional 5 hundy...
SC-
Old Apr 15, 2004 | 07:33 AM
stealth's Avatar
Originally Posted by HUGGER ORANGE SS
No more than 10psi.. ?? huh. Does not make since to me.. If it's true that sucks!!
Stealth, ever thought about running a Holley aluminum intake? You can direct port them and put a bag of ice on it before each race.
Remember I have one and I'm having great luck with it. It does not get that hot at all. A Little hotter than the LS6 or LSX sure. But it's not that big of a difference. Also remember that you can port the intake to match the heads.
I did my 621RWHP pull with a hot motor and hot intake. I was driving in warm weather for about 30 minutes to the dyno day. 10 minutes after I got there it was my turn and I pulled on the dyno with everything being hot. Did 2 pulls. 1st one spun the tires at 5,000 rpms on the dyno. 2nd pull 5 minutes later did 621RWHP.
Pretty cool to see the tires spin on the dyno..
Clint
Clint, You are referring to the LPE-type aluminum manifold, right. I am changing to a 100mm maf and 90mm throttle body. Does the aluminum accomodate those?
IMpressive numbers.
Old Apr 15, 2004 | 11:44 AM
HUGGER ORANGE SS's Avatar
YA the LPE intake.
Go here you can see the intake and the dyno graph.
http://www.dynopro.com/mhhr_detail.asp?ID=5
Not too bad with 11psi, the small P1 blower, and a stock displacement motor.
You can port out the TB hole quite a bit bigger than where it sits now on the aluminum intake. Only draw back, I needed to use GM silicone around the ports to make a tight seal. The intake is very nice but they provide a crappy paper gasket between the heads and intake. I was having Vac leaks from time to time. GM grey silicone cured that right up.
Clint
Old Apr 23, 2004 | 10:33 AM
stealth's Avatar
UPS is picking up my LSX today to be returned to TR for a credit. I bought it before FAST disclosed that they have only tested it to 10 psi and that it probably would not hold my boost. In fairness to FAST, if I really wanted an LSX, I could epoxy and bake it so that it becomes one piece and would never leak, but it's just not worth it for me.
__________________
