would you run this engine FI?
got it home and it wouldnt spin 360degrees.
pulled the pan, and number two rod is bent.
crank looks perfect, bearings look perfect, bore is good and the other rods are fine. engine spins over fine now.
what I want to know is, is this a sign of something a lot worse, or could I just replace that rod and go ahead with my plans.
Im ok removing each rod individually and replacing bearings etc if I have to , what im curious to know is can the rest of the parts still be good if one rod got bent?
pming you now
