oil return
Old Dec 6, 2011 | 07:50 PM
mebanestang's Avatar
Default oil return
anyone returned from turbo into truck pan where oil sensor is? pump needed if turbo is cylinder head height or slightly higher?
Old Dec 6, 2011 | 09:26 PM
MattSapp95_T/A's Avatar
That is not a good location due to the oil being too high and wont let it drain back properly
Old Dec 6, 2011 | 09:37 PM
jasond26's Avatar
its not suggested but mine is plumbed that way. I have taken it to 8200 with no problems. My turbo is mounted about cylinder head high so it has a 6" drop right out of the turbo and then a gradual slope down to the pan. Its -12 as well.
Old Dec 7, 2011 | 01:59 PM
NemeSS's Avatar
Jasond26
Where did u get the fitting?
Any pics?
Old Dec 7, 2011 | 02:02 PM
koolrayz's Avatar
I put mine in there when I was using the stock pan and never had a problem. I ran a
1/2" NPT tap in the existing hole.
Old Dec 7, 2011 | 02:58 PM
Originally Posted by NemeSS
Jasond26
Any pics?
parker has them. cant remember the factory thread but i have one that screwed right in and had -12 or -16 fitting on it.
Old Dec 7, 2011 | 10:02 PM
jasond26's Avatar
I think the thread is a 16mm but I just welded a -12 aluminum bung over the hole.
I don't have a picture of it installed but this is on the engine stand.
I clamped to the pan bolts.
