15psi G-trim combo
Old Mar 14, 2004 | 11:49 AM
S_J_H's Avatar
Default 15psi G-trim combo
Finally able to make some tuning runs on the street.
It's a pretty mild combo compared to some guys out there.
Combo is 348ci, stock cam with 918 springs, modified MAC headers into 3" Y into 4" mufflex.
mild ported 98 ls1 heads with 73cc chambers.About 9.5 compression. MrGasket MLS head gaskets.
fuel system is 42lb lucas at 62psi WOT,aeromotive pump and reg, mallory billet rails, 10an pump feed,8an to rails and 6an return.
Custom alcohol injection system.
G-trim with 2.5" 8rib pulley and 8" crank.
4" inlet ducting to blower with 2.5" to throttle body. No intercooler.
Used cam2 100 octane gas and 15gph denatured alky.
10.0-10.5 A-F ratio. 16 degrees timing at peak torque and 22 at peak power.
Hits 15 psi at about 6400rpm. Charge temps around 170' at 100mph in top of 2nd with 45' ambient. However cruise IAT was 128 before the run. Blower is spinning to 70,500 rpm. AND no belt slip to speak of. Vortech did one heck of a job with their drive system.
With stock Vortech ducting it hit 13psi last year. So the little G-trim is held back a bit with the stock inlet plumbing at max blower speeds.
Feels very strong and power hits hard and instantly
Hoping for ET'S in the bottom 10's after a 9" with spooled 3.50 gears replace the 10bolt and 2.73's.
Steve
Old Mar 14, 2004 | 01:07 PM
maddboost's Avatar
Why no intercooler setup?
Old Mar 14, 2004 | 01:24 PM
slow's Avatar
very nice numbers.
What size is the stock drive pulley for the vortech unit.
Can you send me some info on your 8" or would you want to sell your stock one,, (if its smaller than 8")
Ryan <-- still trying to slowly piece together my G trim kit.
Old Mar 14, 2004 | 04:32 PM
BIGBOS's Avatar
Sounds like a nice setup, might have to meet up to check it out.........
I might have to get one of those alky kits......
Old Mar 15, 2004 | 06:58 AM
cablebandit's Avatar
Very nice SJH. I feel you are doing the most with the least money spent in the FI section. I am still amazed by your 100+ 1/8 mile mph I wonder what it would do now?!
Old Mar 15, 2004 | 09:15 AM
S_J_H's Avatar
Really have not needed one with water/alky injection. But now the blower is really beating the air as I am spinning it pretty fast. I have just begun building a water/air intercooler yesterday.
I am using the parts provided in the kit. The vortech kits come with an ATI balancer and a 8" diameter 8 rib crank pulley.
Hopefully I'll get out to the track more often this year. I would like to check out your car as well.
I try to keep the costs down as much as possible. Makes the wife a whole lot happier.
Steve
Old Mar 15, 2004 | 09:27 AM
slow's Avatar
thanks.
When you said 8" it sounded like you were talking custom. But that is great results, using just the stock one, and a smaller blower pulley.
Those are very impressive results Always nice to push what most people think is the maximum from a product.
Ryan.
