2.5" vs 3" intake pipe...is their a performance advantage?
I am NOT running an intercooler so I was basically going to run a Y pipe right off the throttle body just before the fans. I was going to have it follow straight across the top of the radiator and into the compressor housing. It is 2.5" I was going to either make my own Y and trash the 3" one I did or buy a Y pipe that 71 Chevy posted a while back that has two outlets coming off the throttle body. It looks as though this would make the cold side very simple to do and keep it much cooler. I was just worried if being 2.5 inches instead of 3 inches would hurt any performance. FWIW my down pipe is 3"
Thanks.
Thanks.
Why would you think that aluminized piping would run cooler than steel piping? They are both steel. The aluminized just has a coating on it to keep it from corroding.
In order to know if 2.5" vs. 3" is going to hurt anything, you need to know how much air you are moving first. When you know your CFM then you can calculate it into the size of the pipe. That will give you velocity. I believe anything over about 300 feet per second, and the pipe starts to become a restriction.
EDIT: I just checked... It is 450ft/sec, not 300ft/sec
Also, if you have no idea of the CFM, then you also wouldn't have any idea of the ft/sec.
600cfm = about 300ft/sec in a 2.5" I.D. pipe.
being that you are not going to have a IC i would think the difference between 2.5 or 3 inch would be negligible since you will have less than a foot of piping on each side, your TB inlet would be simlar to 3.5 inch single pipe, so figure out that velocity and match that to the two pipes coming into the TB.
I dont have and #'s on hand though, you might be able to find some by searching
HTH
