Where to get really high temp oil return hose?
Old Dec 15, 2011 | 07:21 AM
SPRAYED 01's Avatar
Default Where to get really high temp oil return hose?
So I'm having a hard time sourcing some good 1/2 inch oil return hose. I've tried a couple differant ones from home depot type places. They get really hard after a couple thousands miles and I'm afraid on a long trip it might crack and leak.
I'm in chicago so local would be great but I have no issue with ordering.
Alex
Old Dec 15, 2011 | 08:05 AM
smokinHawk's Avatar
i used braided fuel hose, that seemed to work well.
Old Dec 15, 2011 | 08:14 AM
02blackbeauty19's Avatar
If you want piece of mind, get some braided PTFE hose and sleeve it with some fiberglass/silicone heat sleeve. That's what I've done with most of my lines that are the most susceptible to heat.
Old Dec 15, 2011 | 04:19 PM
stevieturbo's Avatar
Alex
Post a pic of your setup.
Good quality oil hose should be fine unless routing is incredibly bad. And if routing is incredibly bad, make a steel return until it is safely clear of extreme heat
Old Dec 15, 2011 | 05:01 PM
SirNemesis's Avatar
This is what I do and haven't had any trouble. I did manage to melt a standard rubber braided line without a heat sleeve but I don't have a very good path for the drain.
Old Dec 16, 2011 | 07:59 AM
ss1's Avatar
ss1
Probably braided stainless teflon hose would have the highest temp rating as already mentioned. The other type of sleeve you could use to cover it is the aluminized fiberglass cloth. I used it to cover the heater hose and AC lines on my Impala SS when I put headers on it a few years ago.
