Ati damper
Old Dec 16, 2011 | 10:02 AM
solo21's Avatar
Default Ati damper
trying to get this damper on and just cant get it to line up with the belt, its sticks out about 1 groove. seems like I got the wrong hub or something. anyone ever run across this problem, I really dont want to run the procharger on stock damper.... here is a pic of ATI damper vs stock one... I talked to ATI and they said I have the right stuff, I just cant figure out what Im doing wrong if the problem is on my end...anyone ever have an issue?
Old Dec 16, 2011 | 10:06 AM
Dustin 98TA's Avatar
Have you put it on? Are you sure its bottoming out? Did you have the timing gear off? Is it bottomed out?
Tha ATI damper is thicker at the lip so it will appear that it is not the same size, measure it and you will find that its the same.
Whats the model number?
Old Dec 16, 2011 | 01:45 PM
solo21's Avatar
916812 is the only number I could find on the inner shell, the hub number is 916031s
Old Dec 16, 2011 | 01:55 PM
lmt0705's Avatar
that looks like mine, when its bottomed out there should be a lip in the hole of the balancer that is .256in off the snout of the crankshaft. use the back side of some dial calipers to measure this. thats what I came up with when I measured mine. FYI replace that front seal before final installation otherwise it will leak. ive had no luck reinstalling a balancer trying to reuse them.
Old Dec 16, 2011 | 09:40 PM
solo21's Avatar
Well double checked everything and its bottomed out for sure... I measured the the stock damper from where the seal sits back the measurement is identical on both dampers so now I'm positive It's all the way back but ATI damper still sticks out. At first I couldn't tell but when I turn the car on I saw the belt kept trying to come off then I saw it wasn't lining up... ATI is stumped on this as well so I'm shipping it back for them to look at. I kept thinking it was on my end but I already talked to a few different ppl on here and no one has seen this... Thanks for the input guys.
Old Dec 20, 2011 | 06:07 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Question
Let us know what you find out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
