cooling fan help
Old Dec 24, 2011 | 12:49 AM
tt383lt1's Avatar
Default cooling fan help
hi i have a griffin 1.5" dual core radiator so 3" core stud up vertical ( cut about half the upper support out) . i had some cheap ebay fans on it with no shrouds. my engine temp wouldnt drop below 220 so i put the stock lt1 fans back on with cutting the shroud a lil and moving the radiator under the upper suport due to the turbos and the thickness of the lt1 fans and shroud. it went as low as 170 degree. i want to put the radiator back to were it up vertical spot. any sugestions. and i heard the stock lt1 fans pull 8500 cfm on battery and 9500cfm with the car running.
so one of my qeustions is the nicest fans out there i know of is the spal extreme 16" fans only pushes 3000 cfm is that enough.
and has anyone ever made the stock fans into pusher insted of pullers thanks again any help please.
