post up picts.of turbo motor bays!
Old Mar 26, 2013 | 07:04 PM
  #321
98Camarod's Avatar
Originally Posted by westtexasbuff
Almostttttt ready to fire this bitch up.
Looks good man! How does it look with the hood closed with all that trimmed out?
Old Mar 26, 2013 | 09:27 PM
  #322
Wicked69's Avatar
Dude that looks sick! Did you just run to BOV's so it would look symmetrical? I ask because I have twins but I only run one 50mm Tial BOV. I didn't think you needed two BOV's. Looks mean!
Old Mar 26, 2013 | 09:52 PM
  #323
WheelsUp84z's Avatar
simple twin kit on my 95
single kit on my 99
Old Mar 26, 2013 | 11:33 PM
  #324
55superbeetle's Avatar
My Swedish touring sedan
Old Mar 27, 2013 | 02:30 PM
  #325
Blackpanther99's Avatar
Originally Posted by ls6-240sx
Love it. Very clean engine bay view
Old Mar 29, 2013 | 11:35 PM
  #326
E.rodz's Avatar
is that a holley high ram or a mini ram.? also are you using alum pipe for your hot side pipe?
Old Apr 1, 2013 | 01:15 PM
  #327
Rickys S/C Z28's Avatar
Love this thread!!! Lots of great work!!!
Old Apr 1, 2013 | 05:21 PM
  #328
westtexasbuff's Avatar
Originally Posted by Stangkilr
Looks awesome!!
Thanks man!
I don't know yet, I don't have a hood for it, lol. I'm thinking about going with the VFN 4" sloped hood since I can't get a hold of Joe Van to get one of his.
Thanks You don't need two, but just to be on the safe side I ran 2. A few of my friends run 2 of them as well, so I figured it couldn't hurt, I get them super cheap too so it's just added insurance.
Hi ram, and yes 4" aluminum downpipes dumped straight down. The hotside from the manifolds is 2.5" 304 stainless pipe.
Old Apr 1, 2013 | 07:28 PM
  #329
allout06's Avatar
^^ You did your BOV's the same way i wanted to. Any tips on tac welding aluminum so i can take it to a pro for the finished weld? i have a MIG welder.
Old Apr 1, 2013 | 09:43 PM
  #330
E.rodz's Avatar
[QUOTE=westtexasbuff;17279961]Thanks man!
I do admire your vision to go outside of the box. however I do think the alum. down pipe is a bad idea full boost pulls you will be melting your down pipes!. your stainless welding needs some help as well. please do not take this the wrong way I am not bashing your work just trying to help. if you purge the stainless with a gas such as argon,co2, or a tri mix it will prevent sugaring of the welds on the inside. also turn your heat down you are running to hot. keep in mind any piece of the sugar that brakes off is taking your turbo out! and if you took a die grinder to it you found out it is hard as a rock! you are doing a great job doing the turbo system just need to slow down a bit and keep in mind fitment is key to clean welds! tig stainless with low heat. Alum. if thick walled pipe purged welded with a gap in it so it is full penetration and no mufflers living life 1/4 at a time you might have a chance. again just trying to help not trying to bash! keep up the great work and keep posting!
alum. requires a ton of amperage also a teflon liner for your gun as well as a argon gas for a shielding gas. you are better off just match marking your pieces then bringing them to a welding shop having them tack them. go bring them home test fit everything then everything is ok. bring the first half of your piping back have them weld it . bring it home again test fit make adjustments to the rest of your pieces have them re tack again then have them weld the rest up. welding moves and pulls things around if you have them weld everything up at once i IT WILL CHANGE ! just trying to help I have alot of experience welding and patience is a virtue! fitment is key to any good weld!
Old Apr 1, 2013 | 10:01 PM
  #331
Lots of people run aluminum downpipes without any issues... I know my welding needs work, lol. I've never welded anything in my life before this project. No offense taken. I could have taken the pipes anywhere to be welded but I wanted to say that I did it on my own. Thanks though.
Old Apr 1, 2013 | 10:38 PM
  #332
a4ls2goat's Avatar
Old Apr 2, 2013 | 08:02 AM
  #333
Sweet_SS's Avatar
Old Apr 22, 2013 | 07:51 PM
  #334
E.rodz's Avatar
we have to keep this thread going there has to be more forced induction projects out there!
POST THEM UP!!!!!!!!!!!!
Old Apr 22, 2013 | 10:18 PM
  #335
bad6as's Avatar
Getting closer.
Old Apr 22, 2013 | 11:32 PM
  #336
Gonoma's Avatar
Its becoming more real everyday...97 s10 lq9 home built setup
I wish this forum had automatic resize...
Old Apr 23, 2013 | 12:05 AM
  #337
Slo_240sx's Avatar
370 Iron block, Wiseco pistons, Callies rods, ETP Heads with roller rockers, GT4788 turbo and shaved bay in a 93' S13 240sx. All work done by my hands. Looking for high 900-1,000hp...
Old Apr 23, 2013 | 01:01 AM
  #338
gnx7's Avatar
Nice work Slo240sx! I like that 240z also
Old Apr 23, 2013 | 08:50 AM
  #339
Slow94Formula's Avatar
Done for now...
Old Apr 23, 2013 | 02:04 PM
  #340
L92 fox's Avatar
New pictures with the new turbo and coating
1999 Camaro SS
10 to 1 370
LSA heads/ls3 intake
OFI t4 turbo kit
Pt88 with a gt4788 comp wheel
