Upping The Boost
Old Jan 10, 2012 | 09:11 PM
boosted02's Avatar
Default Upping The Boost
Hello All ,
New to the Forum, Camaros, and Turbos. Just bought an 02 Z28 with the STS rear mount system all stock except the updated rails and injectors that was installed with the kit and looking for advice on what would need to be done to get the engine to handle more boost. Transmission and rear end have already been built to handle more.
Old Jan 10, 2012 | 09:43 PM
ilovechevy1's Avatar
if it's still the stock 10 bolt rear then you will be in trouble at the drag strip on drag radials or slicks. If it's a 12 bolt or a 9 inch then you will be fine. do you know your current injector sizes or fuel pump setup?
