help me decide
Old Jan 12, 2012 | 07:47 PM
T/AWS6969's Avatar
Default help me decide
Ok...i know i can get 700rwh with an ls1 or an ls3. What are the pros with the ls3 over the ls1? The ls3 would be an iron block thru schwanke engines. I know it will be a stronger block than the aluminum ls1. Would i have a better torque curve (generally) with the bigger bore ls3? I do plan on keeping the stock stroke on either one and i will be using a procharger d1. Any input i appreciate. Thanks
Old Jan 12, 2012 | 07:52 PM
T/AWS6969's Avatar
Also i want to add...i am at 5200ft. Will the smaller bore give me a better rpm range because the smaller bore can be boosted easier?? Or can that be just be compensated w more compression if i go ls3?
Old Jan 12, 2012 | 07:56 PM
dschmittie1's Avatar
Bigger motor will be easoer to make the power with
Old Jan 12, 2012 | 09:05 PM
T/AWS6969's Avatar
Thanks! Any any other advise?
Old Jan 13, 2012 | 06:59 PM
T/AWS6969's Avatar
Ttt...............................
Old Jan 13, 2012 | 07:02 PM
babbage1109's Avatar
You have more head choices with an ls3 style block. Bigger bore and newer design. But that being said some of the fastest f/I ls motors are 5.3s
