max boost d1sc 383
Old Jan 17, 2012 | 09:04 PM
Fastdriver1992's Avatar
Default max boost d1sc 383
what is the max boost i can make with this setup. its a 383 ls with ported trick flow 225, ls6 intake, ported throttle body, 1 7/8 lts, and d1sc with all the goodies and boltons. also what pulley should i buy to make max boost and the power it would make with the brute speed blower cam
Old Jan 17, 2012 | 09:17 PM
jjcamaro02's Avatar
You have close to the same setup I have. Depending on how much rpm you are turning a 3.4 pulley would max you out around 6500. If you turn more rpm then go with 3.55 pulley, this would be good to around 7000 rpm.
Old Jan 21, 2012 | 08:08 AM
LS1RedZ's Avatar
^^ What he said. Id just throw a 3.4 pulley on and let her eat! Should be damn stout!
Old Jan 21, 2012 | 11:44 AM
99Ls1fever's Avatar
15 to 16psi
