sts turbo ??
Old Feb 3, 2012 | 02:47 PM
ZL1Killa's Avatar
Originally Posted by nodrok
After seeing the results of the first kit you would do things differently too. Oil in the cold side on the sts kit. you'll see.
I did do things differently, I scrapped all but the cold tubing and did all new items for my build I have now. Never had a problem with oil in the cold side.
I DO NOT have an oil restrictor in the feed line, I have a NON-KINKED and STRAIGHT to slightly curved oil return line to the oil pan with a Turbowerx Exa Pump. i'm not seeing a damn thing but clean pipes.
Unless you are above 70 or so oil feed PSI you do not need a restrictor in the oil feed line to the turbo, Providing you have a good return line for your application.
