need some questions answered
1. will a single walbro 400lph hp pump be enough fuel?im assuming so since twin 255lph will support 1000hp.
2.with a front mount ic will water meth be needed for my goals? i can see at higher boost levels needing it but at 600 hp?
3.can i get away with stock valve springs? or should i plan on at least getting some pac1218 springs?
4.and lastly i can think of would it be a good idea to run a 160degree t stat?
i can see some reasons to,but car is a DD in the pnw and driven in the winter.
thanks for what ever questions you guys can answer.
thanks joe
