2 Step Tuning
Old Feb 7, 2012 | 09:48 AM
dville_gt's Avatar
Default 2 Step Tuning
I posted this on my local forum, but haven't gotten any response.
I got to go out and play with my 2 step last night. Seems to be working pretty good, found out that since the area's of the VE table I hit in the 2 step are never hit otherwise they were way out of tune (very lean).
My question is:
Since there are area's of the VE table and the timing table that I can only hit while on the 2 step (like 3.2k rpm @ 150kpa on the VE table or 1.0grms of cyl air mass @ 3.2k rpm on the timing table), how should I tune those areas.
I have heard you want to tune it rich and low timing as this helps build more boost. What kind of AFR and total timing is ideal. On a side note, can the AFR numbers on the 2 step really be trusted since you are cutting spark and still fueling or does most of that burn up in the turbine?
Oh, and I was able to build around 7psi @ 3.2-3.3k rpm on the foot brake @ 100%tps, should be able to jack the 2 step up a little and hopefully with some tuning get a little more boost out of it out of the hole. AFR was around 12.5:1 and timing was around 20* @ 7psi on the 2 step.
Thanks!
Old Feb 7, 2012 | 10:34 AM
dschmittie1's Avatar
I have seen Phill say that you want to lean things out on the 2 step. like high 12s for AFR Also add more timing there. Fireball also told me when tuning your 2 step set the 2 step higher then what you plan on having the 2 step at and tune that area when you are not actuall on the 2 step function
Old Feb 7, 2012 | 11:18 AM
venom ws7's Avatar
Thats what I remember too leaner with more timing..
