Big Stuff 3 ECU+ boost= awsome
Old Mar 20, 2004 | 12:00 AM
427's Avatar
427
Default Big Stuff 3 ECU+ boost= awsome
Ran my 6.0 turbo with the new gen 3 Big Stuff controller on the dyno to check out the new controller.
It plugs into ALL gen 3 sensors with no adapters! (FINALLY)
Direct to crank pick up.
Direct to COILS!- Chose your firing order with laptop!
Injector timing adjustable based on rpm!
Same box will also run auto trans function.
Auto scale of tps and boost on fuel map.
Also made 1050 ft lbs with ls1 coils...not truck coils! (truck coils also worked)
This box will make many people very happy.....
Kurt
Old Mar 20, 2004 | 12:21 AM
Time2Kill's Avatar
MASS seller approved
Do you have any more info on this controller and pricing etc?
Old Mar 20, 2004 | 08:12 AM
Reckless's Avatar
Super Moderator
Who makes it Kurt? You are holding back information again!
MIGHTYMOUSE's Avatar
i was looking into these before pickingup the dfi. which also plugs directly in but has an ls1 ignition box and a wideband box outside of the ecm.
after i couldnt find them for sale anywhere i kinda had to give up.. guess i was looking in the wrong place.
Old Mar 20, 2004 | 08:19 AM
Jammer's Avatar
Please explain a little more clearly what were discussing here... is the "Big Stuff" another option to Gen7 as well?
Old Mar 20, 2004 | 08:33 AM
Reckless's Avatar
Super Moderator
Might be a FAST thing? Wheel to Wheel does testing for FAST
Old Mar 20, 2004 | 08:38 AM
2001-WS6's Avatar
Sounds like there was some being had up in Flint last night.
Rick
Old Mar 20, 2004 | 09:01 AM
427's Avatar
427
Not a FAST part.
FAST was designed by John Meaney in the 90's
John, Leo and Joe Meaney equal the 3 brothers who started DFI(accel) in the 80's
Big Stuff 3= The Meaney brothers...There back, prepare to feed your racing Demon's
Kurt
PS "NO EXTERNAL BOXES" (had to repeat this)
data recorder= inside
trans controller= inside
coil drivers= inside
boost controller= inside
air fuel brick= inside
Running your gen 3 with one box.....PRICELESS!!
Old Mar 20, 2004 | 09:13 AM
2001-WS6's Avatar
Originally Posted by 427
Not a FAST part.
Kurt
The next question on all the minds in here is when is it going to be available since we know which shop has it in house???
Rick
Old Mar 20, 2004 | 09:16 AM
GMC SKI's Avatar
Well how about some more info on this
When will it be available to the general public and at what Price point are we looking at
There has to be a competitve unit in the market at a lower price
I'm sure if someone built an ecu controller at the $1500 range they would sell many many units
Old Mar 20, 2004 | 10:28 AM
Reckless's Avatar
Super Moderator
Looks like I know what will power mine and your next cars Kurt
Old Mar 20, 2004 | 01:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Worked nice eh Kurt?
Sounds nice. Will Meany be making the boxes himself or will he be able to handle volume?
GM SKI, most aftermarket ecu's are north of $2000 with everything. Most are around $2500. My FAST setup ends up around $2600 I think.
Old Mar 20, 2004 | 02:49 PM
NA$TY-TA's Avatar
Im interested also.............. When will this be ready for the rest of use to buy... and i know its already been asked, but how much and who do we get it thru?
thanks
Kyle
Old Mar 20, 2004 | 04:35 PM
427's Avatar
427
He will be able to handle volume. He will test each box before it goes.
Not sure what all the options will cost, but all the bells and whistles will be under 2400 without trans controller. Trans controller will add 300.
Old Mar 20, 2004 | 04:41 PM
427's Avatar
427
Which shop has it in house?
Kurt
Rick
Old Mar 20, 2004 | 04:48 PM
2001-WS6's Avatar
Kurt
I was joking since you had it out and on the Dyno.
Rick
Old Mar 21, 2004 | 12:34 AM
Whistler's Avatar
Sawzall and Welder Mod
Built in boost controller has my attention! Boost retard with regard to knock sensor input would be the katz meow.
Old Mar 21, 2004 | 12:54 AM
buschman's Avatar
Couple of questions;
Does this have wideband inputs for AFR control?
What good would a boost controller do for a blower car?
Is the trans option something that needs to be bought up front or can it be added on later. Not that I'm thinking of switching side, but I've thrown around the idea of getting a TH400 on the side to run for a few months, but the T56 ould definitely be the main tranny. Just wondering if this system would allow you to swap in and out.
Does a system like this work with the different impedance injectors?
Mike
Old Mar 21, 2004 | 10:34 AM
QuickSilver2002's Avatar
Sequential or bank to bank?
WB input?
Would it work on a c5 with fly by wire?
Old Mar 21, 2004 | 04:46 PM
427's Avatar
427
1. comes with wideband built in for live air fuel corr.
2.boost controller would only work when you have more power than the track or your tires can take.
3.The trans controll box has a different design with wire harnesses pluging into both ends. If you buy the trans control box you can run without it. You only need this controller for a electronic trans, 4l60e or 4l80e. You don't need a controller for a turbo 350, 400 or powerglide.
4. The high and low impedance injectors are both compatible.
Kurt
Mike
