Procharger Hex Standoff Question
Old Feb 16, 2012 | 08:38 AM
No Juice's Avatar
Default Procharger Hex Standoff Question
Does anyone recall which combination of standoffs they used to attach the J-bracket?
I recently got a modified standoff that measures 2.75" but I find out that the one thats on the car is about an 1/8" shorter. I know the manual has 2 different sizes called out for the 8-rib kits (2.65-2.75). It also lists two different sizes for the round spacer for the stock idler location (1.75-1.875).
I haven't had any issues since I originally installed the kit, but I don't want to have this change things now.
Old Feb 16, 2012 | 09:29 AM
KS91Z28's Avatar
The 2.4 hex spacer is for auto trans.
The 2.5 hex spacer is for manual trans.
The 1.5 tube spacer is for '00-'01.
The 1.625 tube spacer is for '98-'99.
Old Feb 16, 2012 | 09:39 AM
No Juice's Avatar
Those are for the 6-rib kit correct? Do you have the same info for the 8-rib?
Old Feb 16, 2012 | 10:15 AM
KS91Z28's Avatar
Your're right. My bad.
8-rib is as follows:
The 2.65 hex spacer is for auto trans.
The 2.75 hex spacer is for manual trans.
The 1.75 tube spacer is for '00-'02.
The 1.875 tube spacer is for '98-'99.
Old Feb 16, 2012 | 12:50 PM
No Juice's Avatar
Well looks like I'll have to search to see if I can find the box of parts from the original install. Not sure why I have the shorter ones in there. Surprised I didn't have any problems.....
