LQ4 S480 Build
Good choice on the Vikings. I have Strange SA's upfront with 300 lb. springs. I just have cheap Comp. Engineering 3-ways out back though. Hopefully will have mine at the track this weekend to get some hits in on it. I don't expect much on the stock 10 bolt though!
let me know how you do be careful with the 10 bolt
6 speed? The Best V8 Stories One Small Block at Time
Good runs Doug, there is a ton more left in it! Do you have a boost controller?
I haven't moved it up just something he mentioned. I have them in the lowest hole wih the relocation brackets but the reason it isn't getting the best times for 60' is the eibach pros in front. I have the adjustable on back to ill be making many adjustments to get it right only had a few passes so plenty of time left.
No I don't need one but can only buy so much haha if something pops up ill grab it. Would like the leash but not spending that kind of money so ill search for a used ams and pick one up for less than 300 bucks. I was just watching the boost gauge and releasing the brake at different points to test launches not very consistent lol but found 6psi was cutting 1.54 on **** suspension.
A Co2 controlled boost controller is a god send on a turbo car.
So turned the boost down to 14 but ran 9.9@142 first pass. Then was told to really keep it under 10.0 so worked on 8th mile got 116 out of it but really couldn't hook so my coil overs come in tomorrow they should help get this pig off the line 1.5s feel like a slug!
Sorry for the shaky video my nephew took it
My pit crew
