Turbo 5.3
Old Feb 22, 2012 | 05:06 PM
SCbuick010's Avatar
Default Turbo 5.3
Alright...like many others Im think Im gonna build a turbo 5.3. I will give you a little run down. I already have a 5.3 with 127,xxx miles. It was pulled from my dads tahoe. Motor ran great. My dad is a tig welder/fabricator so he will be doing all the piping. I want to leave the motor fairly stock to keep it on a budget. I was thinking about using 317 heads, LS6 valve springs, and a LS6 or LS9 cam. I want to get an s480 turbo. I want to run as much boost as possible. Since it is a budget build I wont mind to much if the engine blows up, but i dont want it to get to that point. I just want to push its limits. Any comments or recommendations?
Old Feb 22, 2012 | 11:00 PM
831jd's Avatar
I would leave the stock 5.3 heads and get a used ls6 can... the s480 is a good choice I'm going to run the same Turbo..... need more specs what car you using, drag car, street car?
Old Feb 23, 2012 | 06:07 PM
SCbuick010's Avatar
It will more than likely be going into a 98-02 camaro as there are a few I have my eyes on. I want it to be a weekend street car with the occasional trip to the track. I already have the engine, my dad will fab up the hot side piping along with the intercooler piping, and I forgot to mention I have a freshly rebuilt powerglide sitting in the garage waiting for the right project (just needs the correct bell housing). Like I said I want to push the limits of this build...if it blows up...it blows up.
Old Feb 23, 2012 | 07:25 PM
tta656's Avatar
if you use the 317 heads your Compression will be low and you wont like the ""out of boost " performance...I am going to use the 317 heads and mill them down to get close to stock comression ratio,unless i find out the 317 heads dont flow well,then the stockers will stay...
Old Feb 23, 2012 | 07:58 PM
gregrob's Avatar
317 is the same casting as a 243 with the exception of having larger chambers.... they flow well
