Vortech Oil supply line options
Old Feb 22, 2012 | 06:16 PM
sean1997ws6's Avatar
Default Vortech Oil supply line options
I was wondering if anyone has use a oil cooler adapter (sandwich adapted that goes between the oil filter) for their oil feed and return lines. I dont want to tap the pan with it on the car for fear of metal going into the pan. I have an oil filter snadwich on there now and have the lines run for feed and return. I HAVE NOT FIRED UP THE CAR YET! my questions is, will this work? will it be too much pressure in the charger?
Old Feb 22, 2012 | 10:32 PM
possessed1's Avatar
No I would not recomened doing it that way . You need to get the oil out as fast as possible . When you drill and tap the oil pan just make sure you put a good amount of grease on the drill bit and the tap and go slow and keep cleaning the bits off and regreasing evey 15 seconds or so . It will be fine .
Old Feb 23, 2012 | 03:50 PM
So no one has done this?
