Need help! What A/R to go with?
Old Feb 22, 2012 | 11:59 PM
4CamT/A's Avatar
Default Need help! What A/R to go with?
Well I have a friend that's about to purchase a turbo. The turbo that he is looking at is a Garret gt4788 with race cover. His set up is a built 383 ls1 with 317 heads and all other supporting mods, boost will be in the range of 15-18#'s yes we do knownthe heads are a limiting factor but will get swapped out for an other set... The car well see street time and occasional track time. So what A/R should he go with??. The turbo he is looking to buy has an A/R of .96 will that be to much backpressure? Or to laggy for his set up? Thanks
Old Feb 23, 2012 | 12:02 AM
4CamT/A's Avatar
Oh side note: as of the intake, he has the victor jr intake + aarons elbow and 90mm throttle body
Old Feb 23, 2012 | 11:15 AM
831jd's Avatar
PM Dr Turbo.... Mon he can tell you everything about those turbos....
Old Feb 23, 2012 | 12:40 PM
venom ws7's Avatar
What trans ?
Old Feb 23, 2012 | 12:46 PM
831jd's Avatar
4l80e
Old Feb 23, 2012 | 12:55 PM
venom ws7's Avatar
I Think the .96 will work perfect with 383ci auto trans for street and 1/4
I've see lots of member using the same turbo on 408ci no problems with 18-20psi
