Cam Specs with complete I bought. Advice
Specs:
Diamond 11553 pistons with coated skirts -9:1 with 70 cc heads
Built on new LS3 block
Callies Compstar forged 3.62 stroke crank, 6.2 L
Callies Compstar rods
Clevite bearings
Cloyes timing set
Manley pushrods
LS7 Lifters
Synergy Custom Cam by Rick @Synergy
Heads professionally built by Dave's Engine Machining (Next to Synergy Motorsports)
Ported/polished LS3 heads
Comp 921 dual springs
Manley stainless valves
If the turbos have a good flowing turbine of appropriate size that cam should do ok, may not be optimal but will work. More info on the engine/setup. drag, street, auto etc.
Post the valve timing events if you have them. EVO, EVC, IVO, IVC
Few more specs
Holley Hi-ram intake
90mm DBW TB
FLP Level 5 4L65E Transmission
