Want to build a turbo header
http://www.ebay.com/itm/LS1-Hot-Side...item1e653b208a
BUT... it goes on the Driver side. Just saying... an option to consider.
Good luck.
(Got my rear mount custom build coming back to me tomorrow... hopefully)
(Custom Rear Mount T76 On3 Ball Bearing, stock exhaust otherwise, stock bottom, LS9 Cam. Estimated 500-550 hp... Dyno results coming in soon).
No seriously, what hp you hoping for? What boost level, etc?
Where are you located? I'm in Vegas. My builder is Jim at CalSpeed and Performance out of Bakersfield, CA. He does a lot of business between CA and Las Vegas.
Here's a video of another customer's car that he did. Its a C5 Corvette with Twin T76 BB Turbos from On3 (Rear Mounted). Same unit that I'm going to be using, but I'll only have one.
http://vegaslsx.com/vbulletin/vbtube...yno-Run-850-hp
Give Jim a call if you like, maybe he can help you with whatever's holding you back from your build goal. He helped me through my build goal decision making and had some great suggestions for me along the way.
http://www.calspeedperformance.com/
Again, good luck!
Not to say that rear mounts are going to prevent you from issues, just different ones I guess. I'll let you know! HA!
To each his own, I guess, right?
NodRok, so what issues are you running in to? What kind of problems? What's wanting to make you go to Front Mount? Just curious.
Might try twin turbos, running 2x T76 with .96 AR. Just a thought. That's what that vette was running I think...
Good luck with your build. Hope it works out well for ya.
Keep us posted.
