boosted vaccum sources
Old Mar 6, 2012 | 02:52 PM
81cuttysupreme's Avatar
Default boosted vaccum sources
I am running an ls1 motor, ls6 intake and throttle body, and a d1sc. What can I use for vaccum sources besides the manifold to brake booster lines?
Old Mar 6, 2012 | 04:03 PM
dschmittie1's Avatar
When I still had an ls6 intake I used the port for the Evap purge solenoid since I had deleted all the evap stuff
Old Mar 6, 2012 | 08:41 PM
thanks. i'm just not sure what ports will receive boost now and which ones will not. i still need a couple vacuum ports.
Old Mar 6, 2012 | 09:03 PM
607motorsports's Avatar
^^^ I also used the PCV and EVAP ports for my boost gauge and wastegate. You may want to consider a vacuum block and then you would have as many ports as you would ever need.
