running a turbo setup n/a
Old Mar 13, 2012 | 09:47 AM
that national's Avatar
Default running a turbo setup n/a
well ive pretty much spent my budget for the year and i was wondering how my car might run n/a until i can get my turbo. its a built 370 with around 9.5 to 1 comp, ls3 heads and the cam is- duration 235/231, lsa is 115, and the lift is .621int/.617exh. i also have the holley dominator efi computer. i have a feeling the intake might kill me, its the new holley high ram intake. also i dont think ill be doing any dragracing until i get my turbo, mostly just going to the car cruises, witch is about 20 miles.
Old Mar 13, 2012 | 11:20 AM
SPRAYED 01's Avatar
For going on cruises you will be totally fine. When it comes down to it you will still be faster than a stock fbody and most mustangs. Those cruise to shows all day.
Old Mar 14, 2012 | 08:10 AM
dell's Avatar
You still have decent compression and nothing is too wild in your setup. The Manifold might give up a little on the bottom end but it should be a screamer.
I built a low compression turbo SBC a few years back and tried to run it without the turbo due to lack of $$$ and it was a dog. Once the turbo was i place it was a monster. I learned my lesson. The next motor was 9.5/1 CR and ran great on and off boost.
You'll be fine.
Old Mar 14, 2012 | 11:37 AM
Sweet, thanks guys
