Which gaskets with 1/2" studs
Old Mar 25, 2012 | 09:13 PM
Twotonefreak's Avatar
Default Which gaskets with 1/2" studs
I've got a 6.0 iron block with 4.030 bore and 1/2" studs. What GM mls gaskets can i use? I have a set of gm part number 12610046 and they do not clear these studs. i have to thread each stud through the gasket and then hammer them through to the threaded portion (of the block) then go about tightening the studs. I was told this is normal, but it damn sure doesnt seem right.
Old Mar 26, 2012 | 11:54 AM
WheelsUp84z's Avatar
i'm pretty sure the ls9 MLS gaskets fit right over 1/2" head studs.
Old Mar 26, 2012 | 04:45 PM
stngtamr29's Avatar
I have close to the same setup and I used ls9 gaskets and they were big enough to slide right over the 1/2 head studs
Old Mar 26, 2012 | 06:23 PM
427's Avatar
427
The LS9 engine has 12mm head studs so the holes in the gasket are slightly larger. Also put the gasket on the block, then thread the studs into the block.
Kurt
Old Mar 28, 2012 | 08:39 AM
Thanks guys. I got some LS9 gaskets yesterday. They drop right on by threading the studs through them.
