Is a blow-through setup reliable with the stock MAF?
Old Mar 26, 2012 | 11:12 PM
slpfirehawk415's Avatar
Default Is a blow-through setup reliable with the stock MAF?
Somebody told me the MAF needs to go before the turbo pressure. Is that true? I wanted to put my stock MAF sensor close to the throttle body so the blow off valve doesn't mess up the tuning, a blow through instead of a suck through system. Will this be reliable after I tune it?
Old Mar 27, 2012 | 01:42 AM
stangtrader's Avatar
I was going to do a blow thru set up as well and it seemed like the better way,but I would go SD. Is there a specific reason your wanting to keep the maf? I honestly am very happy I went 2bar SD. My tune so far has perfect driveability and it's smoother than it was with the maf when I was NA.
Old Mar 27, 2012 | 03:50 AM
itsslow98's Avatar
My car has a blow thru conversion that was done by Fastlane motorsports. As far as Ford go tunability is WAY better with blow thru over draw thru. I have no complaints other then the location of the damn thing inside the fender well. It is after the BOV/intercooler and ends up quite a good distance from the TB.
