downpipe/ exhaust size?
Old Mar 27, 2012 | 11:09 PM
LS1TA385's Avatar
Default downpipe/ exhaust size?
Trying to finish up my 408ci s475 build and I need some input on the downpipes and exhausts size. I have 2.5" crossover pipes to a t6 s475 but I currently have a 3" downpipe. I have a base tune and have been driving the car some to work all the bugs out before the dyno tune and the car is really slow to build boost. Although I need to check for boost leaks and a good tune will help with spool I am afraid that the 3" downpipe is restrictive. Any input?
Old Mar 27, 2012 | 11:14 PM
itsslow98's Avatar
Open downpipe right now? Whats your intake setup?
Old Mar 28, 2012 | 06:15 AM
LS1TA385's Avatar
I have 3"downpipe to a 3" dynomax bullet and turn down just before rear axle. Ls3 intake and heads
Old Mar 28, 2012 | 07:37 AM
Old Geezer's Avatar
Talking An idea....
Before I changed the exhaust, I'd get the tune done. Slow spool could be many things, all the way from the tune to the converter. [Assuming this is an auto.]
A bung below the turbo flange would be a good idea. That way U can check back psi when doing the dyno tests. That infor could help determine the need for a bigger dp.
FWIW, I run a 3" DP on my GN... Made 840FW, thru a pair of Dynomax turbos, out the back..
[But, that was only a v-sicks...]
Old Mar 28, 2012 | 09:14 AM
rotary1307cc's Avatar
you will see a noticeable restriction as the power rises
on my car above around 11psi the power difference gets substaintial when i have the cutout open or closed
the exhaust is similar to yours and the cutout comes nearly directly off the turbine discharge
its not to say you couldnt make a buttload of power, just not as much as it would
Old Mar 28, 2012 | 10:20 AM
LS1TA385's Avatar
Thanks guys, I have all the hot side wrapped to help with spool too and I will check for boost leaks but I think the tune is the key. I plan on going to a 4" downpipe when I get my k member
Old Mar 28, 2012 | 10:21 AM
1BADAZZSS's Avatar
Outlet is a 5" right, and its necked down to 3"?
Old Mar 28, 2012 | 10:53 AM
LS1TA385's Avatar
Correct. 5" to 3" has me worried a little. Im only going to run around 8#s but I wonder how bad it will hurt dyno numbers
Old Mar 28, 2012 | 11:08 AM
1BADAZZSS's Avatar
Or even worst, lift a head due to high back pressure. They say to try and stay within the size of the outlet within a inch. Cause the turbo was designed to flow a certain amount of air of the outlet size.
My bmr turbo k is a pain. Hard to fit a 4" pipe through the location they designed for the dp, due to the flange on the truck mani being right there. Had to run a sharp 90 of the collector for my crossover and the 4" do still hardly fits.
Old Mar 28, 2012 | 12:15 PM
LS1TA385's Avatar
Which side are you running your do cause I am keeping a/c so I have to run mine on the drivers side. Does anyone make a k member besides bar that has room for dp
Old Mar 28, 2012 | 12:17 PM
LS1TA385's Avatar
Damn phone! * BMR
Old Mar 28, 2012 | 02:53 PM
dschmittie1's Avatar
I am running a 4 inch down the drivers side with my BMR turbo k memeber
Old Mar 28, 2012 | 03:12 PM
1BADAZZSS's Avatar
Any pics? Truck manis, bands?vbands
Old Mar 28, 2012 | 03:17 PM
1BADAZZSS's Avatar
My s88 is flipped other way with dp on pass side
Old Mar 28, 2012 | 09:47 PM
Plenty of pics in the build thread linked in my sig
