Going for 9's
Old Mar 28, 2012 | 08:30 PM
ChadGilbeaux's Avatar
Default Going for 9's
Started working on the truck finally after 6 months of sitting..
Original set up
2006 6.0 stock long block
Ls6 intake
Eps camshaft
KB t6 gt91
Alkycontrol kit single nozzle
4l80e stock
Yank pt3600
12lbs boost 19* timing 689rwhp
(didn't last long got all the main bearings and 3 rod bearings)
Machine work is done on the block assembly starting this weekend...
Stock crank 10/10
Callies
Old Mar 28, 2012 | 08:36 PM
Callies ultra h beam rods
Weisco pistons
ACL coated bearings
TEA built TFS 235 heads
Same intake
Nitrous outlet plate kit with stand alone fuel system c23
Ams 500
Lonnie's twin in tank set up with new lines rails and regulator
96lb injectors at 43psi
Afco dbl adjustable rears
Smiths assassin bars
Bogarts with 295/65/15 drag radials
Old Mar 28, 2012 | 08:45 PM
stock48's Avatar
9 Second Truck Club
Should be a walk in the park with that setup long as you can hook it, and everything works together.
Old Mar 28, 2012 | 09:17 PM
Yeah I had a guy that's real good gonna set the suspension up for me...
Your truck hauls *** for a small turbo
Old Mar 28, 2012 | 11:08 PM
Wicked69's Avatar
What fuel?
Old Mar 29, 2012 | 11:28 PM
93 with meth 2 nozzles
