TWINS feed/return tips please...
Old Apr 1, 2012 | 09:18 PM
ninetres's Avatar
Default TWINS feed/return tips please...
Long time no see Car is nearing completion! Not exactly sure how to feed/drain the twin set-up. Here is the scoop:
FEED
--Already have a 1/8" NPT drilled into that fitting above the oil filter. The orifice on the fitting is pretty small and adequately oiled my T76gts, and ST80 on my previous set-ups. Can I just drill the fitting out a tad, and run a -4, with a -4 T-fitting at some point, with a -4 then going to each turbo? Will that be enough oil?
--Other ideas?
DRAIN
Can I run a -8 off each turbo into a Y-fitting (-8/-8--->-10) that drains into the -10 fitting I already have on my oil pan? Or is that set-up too small???
Thanks for your help!
Old Apr 1, 2012 | 09:21 PM
LS1PUNK's Avatar
Not sure on the feed but Ive been told not to connect the drain lines.
Old Apr 1, 2012 | 09:57 PM
slpfirehawk415's Avatar
1/8 sounds pretty pinner to me, I bet it could possibly work but I would definately drill and retap, I used a 3/8 in mine and its perfect, its as big as you can go with the peice pretty much and it seems like what it was made for. With a 3/8 I don't think you would have a problem linking them up. What type of scavenge pump ar eyou using or planning to use?
Old Apr 1, 2012 | 11:29 PM
FasTimeSS's Avatar
that should work fine
Old Apr 2, 2012 | 08:38 AM
02blackbeauty19's Avatar
Are the turbos journal or BB?
-4 lines will be sufficient IMO, but you may need restrictors if they are BB turbos.
On the drain, I would use a -10 minimum from each turbo and I don't really see a problem with Y'ing them together. I've done it without issue for years.
Old Apr 2, 2012 | 11:45 AM
98Camarod's Avatar
-4 for the feed and -10 for the drain. You can t the -4 and -10. I have a t for my feed but I have two separate drains welded up on my pan.
Old Apr 2, 2012 | 04:27 PM
ninetres's Avatar
Turbos are journal bearing. Looking to run a -4, with a T for the feed, and Y two -10s together into a single -10.
Anyone tried a similar setup and have it not work?
