A2W mounted in front
Old Apr 5, 2012 | 09:03 PM
Martin718's Avatar
Default A2W mounted in front
Just curious on some thoughts on mounting my A2W somewhere up front on car, I was going to put behind the dash but think thatd be a pita so I'm thinking about mounting it up front somewhere. Only concern was if it'd be too much weight up front?? I've done a lot of weight reduction and removal from upfront and run a burkhart front support and stand up radiator with remote pump. I've got plenty of room just curious if it's a bad idea weight wise
Old Apr 5, 2012 | 09:14 PM
68 SS's Avatar
Mine is going in the LF behind the headlight, it is not that much weight even with the water figured in....go for it.
Old Apr 5, 2012 | 11:13 PM
BigBadWhitey's Avatar
I did that as well, on a supercharger setup. Sits right behind the driver turn signal.
Old Apr 6, 2012 | 10:18 AM
Martin718's Avatar
Cool that'll really make things a lot easier then
