50mm Cog Belt Issue
I'm little worried about my belt after talking to a buddy here on forum, he has a 50mm cog set up on his and he shredded 4 belts.
He is running stick in his car and I have TH400 could that be part of problem bashing gears through stick?
Thanks
http://www.youtube.com/watch?v=sASrMa323SE
http://www.youtube.com/watch?v=HQwlqtY8GOM
Alignment is super critical with the cogs, and there needs to be sufficient idlers to control belt orbiting so it isnt flapping all over the place. But mostly alignment.
It made 656rwhp/632trq that was 15psi 16deg of timing 94 octane at 6200rpm on mustang dyno through TH400 with wheel spin, I will try to put it on dyno in couple weeks with some weight in trunk.
Went for drive, one crazy street car
http://www.youtube.com/watch?v=0UpYp...ature=youtu.be
http://www.youtube.com/watch?v=LpcPL...ature=youtu.be
YSI comes more smoother then procharger in my opinion, it made 15psi about 4000rpm i think, I have to look at my logger.
It is more aggressive then D1SC, you cant compare the two.
I have 305/35/18 Mickey Thompsons and breaks them loss through all three gears, I need to get some traction before i up the boost
