Need help choosing new turbo cam
224/224 .581/.581 116 LSA
The car makes good power right now but it peaks around 6000-6100 then drops off hard . I like the smaller cams with a smooth idle . I was just wondering if anyone has any Ideas on another cam that might pick up all around and alow me to peak around 6500-6600
My current motor setup is
aes 390 shorblock
As Cast Trick flow 220 heads
ls6 intake ( I have a fast 102 Im installing this week)
c5r timing chain
APS extreme twin turbo kit
4l80 trans
9 inch rear 325 gears
I was thinking of a 230/230 115 lsa cam but I am worried about idle quality
I had a custom cam ground for my twin kit as well. One thing the guy said who came up with the profile was "you don't want the cam getting in the way of the turbos." We were speaking about rpm limits. He talked like the cam did not necessarily dictate RPM limits as they do on a N/A engine.
It does not matter what boost I have in it it peaks at the same rpm
BTW This car is a friggen beast so its not like Im not enjoying it but I have a feeling I can be doing alittle better than I am right now. OFcourse the unlocked 4l80 and the 9 in and steel driveshaft arent going to help the dyno numbers but I am more interested in the track times and not breaking.
All help and suggestions are very appreciated
Normally I am a CompCam guy all the way. When I was researching the "what cam" question the information I found was many of the guys who were throwing down numbers that I liked(big) and were doing it with small twin setups (61's and 62's) were running Bullet cams. This info was acquired from several sources. There is a guy there who is particularly good at specing cams for turbo cars. Especially when you have all the right info like head flow numbers and so on. A custom cam is no more than a shelf cam.
And your rockers are as big a problem as the XER lobes.
