Catch Can for boosted applications. Review inside
He said at my power level that the sts solution would not be sufficient. He told me he had two different size cans for boosted applications and that in my situation I needed the MONSTER. *He overnighted the Monster Catch Can and I installed it yesterday.*
On my setup it was much more involved since I have twins all the way out back. You put a breather cap that he includes on oil fill, one goes to intake manifold on passenger side, one on driver side valley cover and third as close to boost inlet as possible. In my case I had to run a -10 line all the way to the rear of the car and tee it to each pipe as close to turbine inlet as possible.*
Well the review is in and the RX Monster Can is as advertised!! *No more smoke on decel and rings are indeed seated properly. Next week I should be off to the DYNO to see what she can do with current t wastegate spring setup. I want to avoid using boost controller for now.*
She should be nasty!!!
Sent from my iPhone using Tapatalk
