Spring upgrade
Old Apr 8, 2012 | 11:45 AM
Sweet_SS's Avatar
Default Spring upgrade
Comp 226/232 LSA 115 blower cam .568/.574 lift
Comp Cams - GM LS Dual Spring Kit
w/Springs/Retainers/Seals .650 Max Lift
COMP - GM LS-Type Trunion Rocker Retro Upgrade Kit
Smith Bros. - 5/16 X .083 4130 One Piece 7.400 pushrods
Lifter buckets
LS7 Lifters
LS2 tensioner
GM Water pump
GM Oil pump
Katech - C5R Timing Chain for GM LS Series Engines
GM - 1998-2002 Camaro V8 Damper
GM - LS1 Water Pump T-STAT Housing
GM - T-STAT Bolts
All was installed by JDP motorsports in Utah. Car is currently being dyno'd. Will report back with numbers.
