Boosted Ls3 intake ?
Old Apr 16, 2012 | 08:19 AM
CyaPussy's Avatar
Default Boosted Ls3 intake ?
What are you guys putting in the hole where the map sensor goes on the front of the intake so that it does not blow out under boost?
Old Apr 16, 2012 | 08:32 PM
LS1NOVA's Avatar
Ive used an 1/8 npt plug threaded into it on an LS1, Im assuming that would work.
Old Apr 16, 2012 | 08:38 PM
1Legged60ftHnter's Avatar
My question to you is: Where are you putting your map sensor? I was just planning to extend the harness and run the map sensor in the front of the intake where there is a provision for it rather than plug the hole.
Old Apr 16, 2012 | 11:01 PM
So.jerZ-28's Avatar
Same thought I had... hope your not drilling a hole in rear of intake to install map in stock ls1 location... that would be just assinine.
Old Apr 17, 2012 | 12:32 AM
Oh4GTO's Avatar
I put the MAP sensor there. Perfect fit actually.
Old Apr 17, 2012 | 08:34 AM
CyaPussy's Avatar
My map sensor is connect with a peice of tubbing below the hole. Im scared to thread anything into I dont want it to blow through the hood of my car any other ideas?
Old Apr 17, 2012 | 07:37 PM
thirdgen60's Avatar
blow through the hood??? pretty sure that wouldnt happen even if it came out. If you arent using it and dont want to thread something in it, just machine a flanged plug with an oring groove and clamp in the hole
