Turbo 370 Build/Questions
My goals are 700-800 to the wheels. The car will see the track but will probably be driven on the street more than the track. If it ran 9s id be happy. My budget is to spend the least money as possible. I got a little over 8,000 out of my camaro so id like to build the car for around that. I know ill end up spending more than planned like any other build. Id like to have a setup I could upgrade down the road like throw a forged crank and a good set of heads on in the future and let her eat.
What do you guys think of my setup so far? The PT88 good for me, and should I get a T4 or T6? Do I use the 317s and save up for some thicker deck heads later on? Any tips or suggestions would me appriciated.
Thanks
Thanks
I only recomended a 76mm because your goal was 700-800 at the wheels and you mentioned a manual trans....it would spool up fast and be great for driving around. Versus a bigger turbo w/ a manual trans would spool up slower, if you had a auto/stall to compensate, its daily driving characteristics would be way better. Depends on what you want to do w/ it really... you need the entire picture laid out in front of you to design a perfect system.....perfect being for YOUR needs. Trending Topics
that fox will go easy 9s on a 76 and like stated above will spool alot better with the 76 on a manual.
we have a car here local that had a 76 on is car (manual) granit the guy could no drive
made 830ish to the tire and traped 140 and had a slip of 11.3et... I hate to even think how slow the car would have been with a 88,
go with the 76 and work up to the 88 or go auto from the get go
Thanks for the suggestions.
best case I can only come up with 10.0 with the 317 thats using a .036 gasket and the deck perfect to the top of the piston.
I would look into 243 to get the compressin up to the 11.0 with a .051 gasket it will be right at 11.0 if the deack is perfect with the top of the piston.
thats using flat tops on both with only -3cc valve relifes
You necessarily don't need 11.0 compression, I just suggested it because you are going to run e85. If can get it up there it will only help you. The smart thing to do with the shorter stroke engines with bigger turbos, is to rev them higher to broaden your power band. They might spool later than bigger cube stroker engines, but you can have the about the same rpm power band range just at a higher point.
