Pressure drop across intercooler
You're using a small pipe, so it only takes a small bleed, ie the MBC to affect your pressure test readings to give a false reading.
You cannot take the results as accurate if your test port is the same as the MBC.
Set up MBC so that I get 15+ psi in the manifold.
BUT pressure drop across intercooler also increased to almost 5psi at the peak. Pressure lines were on separate ports, with no MBC on them - of cause this didn't affect readings.
So I guess it's time for Treadstone TR-12 4.5" thick cooler, what do you think?
Bigger is better with intercoolers. A good read about designs. To make sure you get what you need, dont just blindly buy an off the shelf unit.
Contact the seller, give as much detail about your build as possible and then buy the biggest that they recommend.
http://www.are.com.au/techtalk/intecoolersMR.htm#Bar and Plate or Tube and Fin?
From what i can gather air flow into the core is one area where you can massively reduce restriction. good airflow across the whole core should reduce presure drop and increase cooling.
Anyway my IAT's are good & my car runs 9's on a little tc turbo so it can't be that bad I guess.
Anothr reason I got rid of it was because of weight. I think it was like 25lbs.
Another reason was air flow to the radiator.
And last was I think it was a restriction. I mesured my boot at the manifold. I did a back pressure test on the turbine. When the engine saw 11 psi at the intake manifold I had 14psi in the hot side. Could it be that the turbine was too small? It was a 87mm and a 1.25 ar. Could of been a little small yes. But let's say the intercooler was droping 5 psi. That means the compressor would of made 16psi. W/o a ic the engine would of seen 16psi. Bp would of been the same 14psi. All in all the turbo wouldent of had to work as hard to get the same boost to the intake manifold
But just in case the meth fails or iat get too hot ill have the iat retard table in hptuners set to pull timing
I was spraying pre & post turbo, hit way over 200 degrees iat before I realized it & it pre ignited on cylinder 1 as soon as it hit 3rd. I was running without a hood and the dip stick flew out of sight into the air.
Some people claim to have no problems but I sure did.
P.S. Both my Ebay intercoolers did lower temps very good BUT posed restriction. Previous 3.5" (tube and fin) caused my 7psi differential gauge to go off scale.
Now with this 4" bar and plate, I see up to 5psi, but at much higher power.
I need to decide which Treadstone IC I want - usual horizontal flow (TR-12) or vertical (TR-259)
Chris.
also even thoe the ebay 4" ic is 4" thick the in/out are still only 3" od if you mesure the id of that 3" in/out and its near 2.8"
Chris.
