boost referenced regulator in the trunk ?
Old May 9, 2012 | 12:57 PM
s57_s2k's Avatar
Default boost referenced regulator in the trunk ?
right now am collecting parts for a twin turbo setup.
the question is can I run boost referenced regulator in the trunk ? with a hard line from the engine for the pressure signal ? will it add any lag to the fuel delivery ? I want the unneeded fuel to circulate near the fuel tank .
Old May 9, 2012 | 01:03 PM
oange ss's Avatar
you will have response issues based on fueling demands
Old May 9, 2012 | 01:48 PM
DavidPHumes's Avatar
Once the system is pressurized I don't know why it would make an appreciable difference.
FWIW I'm running my regulator back by the rear end and don't anticipate any issues. I know of another RX-7 that runs the same setup with no ill-effects.
Old May 9, 2012 | 01:59 PM
oange ss's Avatar
more in transient areas, not so much steady state. Will he lose an engine over it, probably not.
Old May 9, 2012 | 02:12 PM
123quattro's Avatar
This is essentially how some return-less fuel systems work. It should be ok. Don't make the vacuum reference line too big of a diameter.
Old May 9, 2012 | 05:48 PM
JAX04's Avatar
Why??
Old May 9, 2012 | 05:51 PM
JAX04's Avatar
Who? Zac moved his upfront, Pretty sure it was because of this...
