HOT SIDE temps........curious how high they get.....
Thanks.
Also....what size ID pipe needs to be used on a GT55 outlet port into the cold side pipes?
What size ID pipe needs to leave the exit port on an IC going to the TB?
Really, you need more info to do this stuff, but if you just want to ball park it...
I'm going to make a wild guess and say you run the thing at 15 psi. At that boost pressure your inlet temp should be between 250 deg F and 300 deg F.
All of this is before the intercooler.
