Intake advantages in turbo application?
i wouldnd say miss mathed but it would be a peak horsepower build. low end would be "ehh" then mid to high end would be "sweet JESUS!!!" lol all things equal of course.
if your looking for over 900hp your definiatly heading in the right direction.
I bet the people who put thousands of $$$ into building their forged setup don't like to read articles like that 4.8 one. Makes me want to pull my original engine and dump in a 4.8! LOL!
sorry to rant but anyway,
for turbo builds that 4.8 with twin 76mm turbos would probably be a blast to drive if tuned properly and CONSERVITIVLY lol just remember they had it on an engine dyno and not in a car so some things will be different.
If I did store the original LS1 and put in a 4.8, I'd keep the tune conservative too. But I'd be Hella happy with 750 rwhp! Talk about a fun street car... in my convertible too! WOW! That would freak some people out! hahaha
i myself am trying to research and put together a custom rear mounted turbo setup myself and am trying to get it started but just keep running around in circles as to what size turbo i shoudl go with on my stock LS1. i know the generic anwsers and stuff but want to know some specifics. with your twin 76mm turbos i would most definitly assume your running a front mount lol
Actually I'm running a rear mount right now. Single Turbo. ON3 T76 Ball Bearing with a .96 AR housing. But I just bought a .81 AR housing the other day. Want to see if it helps with the spool time.
Just finished wrapping the exhaust from front to rear today. About to take it out for a test drive and see if it helped much.
I'm stock bottom end. Only mods to engine are LS9 Cam install and LS6 springs. Also running front mount intercooler and snow methanol injection.
Well, I just finished wrapping the exhaust from the cats to the turbo last night. WHAT A DIFFERENCE! The spool is still a little laggy though with my .96 AR. I received my .81 housing in the mail the other day so I will be swapping that out and seeing how it performs. I have a feeling that it will improve the spool considerably, yet not cut top end performance any. At least I'm hopeful. Oh, I also wrapped the coldpipe from front to rear. When I had the car at a muffler shop to fix an exhaust leak at the new wideband bung, I reached up there and touched my coldpipe. That ***** was HOT! It's so close to the exhaust that the heat was transferring and increasing my intake air temps. The pipe had to be 180 degrees or more. Too hot to touch for more than a split second. Lesson learned... WRAP EVERYTHING!!! ( honestly, I didn't buy into it, but NOW I'm a believer!)
Will let you know how the turbo performs with the .81 AR exhaust housing once I get it swapped. That'll probably be in a week or two.
http://www.performancetrucks.net/for...thread-392089/
There are a few other threads like this around the board. You may be able to find them with a search. Good luck!
So, the results are in. Even with the Ball Bearing version, the T76 by On3 Performance needs the smaller A/R for spooling. With the .96 AR housing, I was seeing 2 lbs boost at the top of 1st gear. Now it gets up to 5 psi at the end of 1st, then up to max (9psi) very quickly in 2nd gear. I could probably get even more if I wrapped the cats and the stock exhaust manifolds, but I just don't feel like it. I OFFICIALLY HATE FIBERGLASS NOW.
Anyway, my advice is definitely go with the .81 AR housing for the rear mount (on3 T76).
