Which t6 turbo for lq4
Full boost will be between 13-15psi.
Cam timing is critical in a turbo set-up. Mainly evo.
May as well buy once.
I do agree with you that with a smaller cam the 83mm would spool the same or faster, but I know with the right cam the 96mm will act exactly the same. You're introducing the same amount of exhaust gas into the 83mm turbine with a smaller cam as you are with a bigger cam with proper evo and a 96mm turbine.
4.8 ls9 cam s472 83wheel 1.10 t6 t56 1psi by 2600 full spool by 3200 10psi for now
Ls1 383 blower cam s480 96mm wheel 1.32 t6 t56 makes 1 psi at 2350rpm and full spool 15psi by 3500 for now need more meth...
You can easily make the 1.32 96 wheel work but most people wanna pull stumps (full spool 1000rpms)
But when we are trying to spool a bigger hotside that tighter lsa and more exhaust duration is needed.
